It is currently Mon Jul 28, 2025 6:56 am
PostPosted: Thu Aug 14, 2008 4:41 pm
First name: Jim
Last Name: Samuel
City: Langhorne
State: PA
Zip/Postal Code: 19047
Hi,
I am working on a 1974 Martin D-18. It's one of the Martins from that era that has the bridge located in the wrong place, so the bridge needs to be moved. While I am at it, I'd like to install a bridge with 2-1/4" string spacing.
I really don't feel like making a bridge right now. Can anyone tell me where I can get an oversize rosewood Martin-style bridge with 2-'1/4 inch string spacing?
Jim
PostPosted: Thu Aug 14, 2008 4:56 pm
jwsamuel wrote:
Hi,
Jim
Stewmac sells oversized martin bridges but they maintain the 2 1/8" string spacing. Just curious but have proofed out that the existing neck taper works with 2 1/4" spacing? You are likly going to have to make from a blank to get tha spacing on Martin style unless one of the CNC guys will make one for you.
PostPosted: Thu Aug 14, 2008 5:55 pm
That D-18's neck is made for the 2-1/8". Unless you want the strings close to the edge.
PostPosted: Thu Aug 14, 2008 6:07 pm
First name: Jim
Last Name: Samuel
City: Langhorne
State: PA
I'll have to measure for myself on the string spacing. I was told that 2-1/4" is a better fit than the stock 2-1/8" spacing. I'll check it out before I do anything.
Thanks for the help.
Jim
